Hello forum members, I’m in need for some 70-73 350 front Engine brackets, alt, steering pump, a/c as well if anyone has any that would be willing to part with, I believe the motor I have is a 70-73 , I know you members have a lot better idea that will work for me, Thank you
pinion head here probably has everything you need, or for sure can tell you what you need. He'll probably chime in when he sees this thread.
Hello
uh oh
call me tomorrow I should be able to help out with pulleys and power steering for 71 n newer
I have 70 stuff also ... ac brackets n pulleys too
what year are you working on ....
Scott
206 465 9165
pinion head can probably help tooo
I appreciate your help bigD and Scott, here are some pics of the motor before I pulled it out of the car ( which was a 1973 Lemans Sport Coupe with GTO package ). Motor seems to run really good considering it’s looks and it cobbled mess. Hope this helps, I really don’t need the a/c brackets due to most of that has been removed somewhere before I took ownership of the car. Thank you
Oh and I meant to mention , the story I also was told by the person I bought it from said that the 400 that the car was born with was blown up, pulled and replaced with this motor which I guess is a 350, and a mild cam, Edelbrock aluminum intake and the carb that was on it was a quadra jet four barrel which was in dries need of a rebuild which I was able to buy a Edelbrock 1406 carb off eBay which truely helped this poor motor start and run. Now, I have forgotten a lot when it comes to Pontiac engines, but I’m thinking someone has put the 400 cid cylinder heads on the 350 block, but not 100% and I’m sure someone could help me out and truely find out. Thank you
