i own a 71 goat with a 400, i was wondering what modifications can i do to increase overall power without taking a huge chunk out of my wallet? thanks for your help.
If you change a cam find out how big you can go without having to adjust the heads, add headers and gears, etc to get the horsepower it says it will give you from that size of cam.
i did some research and found that the comp xtreme energy 268H was good...does anybody have this setup or know if i can use this with my stock 400?
I heard a guys car with a CC 268 in it, car had a nice sounding exhaust lope. Great compromise cam between stock and hot. Don't need a big stall converter and still sounds real healthy. I'm probably going with the CC 280 in mine, but that car is a toy and I want a nasty idle.
Check Lunati voodoo cams, they have some new cam profiles that are much improved over the old school cams, more advanced. Also, the magnum 270 cam is just a little bigger than the 268.
