Hi gang, I am having trouble pulling the ignition lock assembly. I understand from the shop manual tha there is a release that must be depressed. I have submitted a photo in hopes someone has pulled theirs before and might help me. The book says to insert a screwdriver or knife blade in the slot next to the turn signal hold down boss. Not sure which one is correct. I tried #1 and #2 but can't feel the release. thanks for any help
Discussion Starter #2
Well, found an illustration in manual that shows a flat metal ruler stuck in the slot #2. I just can't seem to find the release.
Thanks, Got it. From the scratches on the cylinder, looks like i was actually hitting behind it for awhile. Works perfect but broke the black plastic shaft that the horn spring goes in, while putting the wheel back on. I guess i'll try and super glue it. Thanks again
