What would a set of 7K3 be worth? I know that you cant run headers with these, just manifolds. Any other problems with these heads?
Who says you can't run headers? You just have to get the right kind (D-port headers, not round port). 7k3's --- big valves (2.11/1.77), screw in studs, and 96cc chambers (nominal). Put those on a 461 with flat top pistons, run a 0.040" compressed thickness head gasket, zero deck the block, and you'll be at 9.517:1 static compression ratio. Add a cam with some attitude and a 'later than usual' intake closing event and that's dang near perfect. Flat tops and zero-decking will give you good quench area for lots of turbulence and minimal exposed edges in the chamber --- both very good for detonation resistance.
If you're going to run iron d-ports on a big inch Pontiac, that's about as good as it gets.
