Your missing a lot of wiring
That’s for the radio
Do you have am ?
Am fm. ? Am-fm stereo?? Rear speaker?
it all matters on getting the correct harness
buy one from “themgrandprixs “ on ebay
I have a few spare harnesses
for the 8 track s
But I don’t have them all labeled
has your player been tested or is that what your trying to do?
yellow power
Blue rear speaker
Green front speaker
Gray illumination
I believe both 67 & 68 Pontiac Tempest, LeMans, and GTO are wired the same with AM, AM-FM radios wired as mono front & rear. The 7298842 8-track stereo tape player internally switches the mono from the AM,AM-FM radio into L in front and R in back. AM-FM Stereo Radio units were available in 67, 68 full size models and the 8-track harness is slightly different from the A bodies to allow stereo in both radio or 8-track modes all the time. If you're doing a retrofit, the F-R or reverb switches are not needed. The BALANCE control on the 8-track player does that job whether your using the radio or player. A full size 8-track harness can be modified to work in a GTO.
The tape player is a T-200 model. I call it the "Terminator" version because it's built so rugged. You may want to take the cover off and clean out the tape debris. If you haven't already, you'll need to replace the belt. The right circumference and diameter is important. Too tight and it'll sound slow. Too loose and it may wind off the pulleys during use. I use a PRB OA14.8 (14.8" circumference, 0.070" cross section dia. round belt). Today's belts' rubber compound stretch differently and this size isn't too tight that it slows the tape speed, nor too loose that it falls off. I tried NOS replacement belt 1222760 but it was shrunk, took a set, & would not work correctly. (FYI, it was 13.6" long x 0.070" square). The bulbs that illuminate the STEREO and TAPE indicators are GE250.
The warnings that speakers need to be connected prior to operation on AM, AM-FM radios applies to the 8-track player as well. The amp circuits are identical.
I've attached some wiring diagrams to aid in your efforts. In the future, consider making your own 8-track to bluetooth adapter. When they ask you "What's an 8-track?", you can say it's a device that connects your cell phone to the car. :)
Plant Twig Asphalt Circle Wire
Electric blue Auto part Gas Fashion accessory Composite material
Font Rectangle Parallel Auto part Handwriting
Product Rectangle Map Font Schematic
Property Rectangle Map Font Line
Rectangle Font Parallel Music Diagram
Electrical wiring Audio equipment Cable Gas Gadget
Font Parallel Paper Paper product Document
Font Parallel Paper Document Screenshot
Automotive lighting Vehicle Motor vehicle Gas Hood
Discussion Starter · #5 ·
Do you have am ?
for the 8 track s
yellow power
Blue rear speaker
Green front speaker
Gray illumination
Thank you. I have a AM/FM stereo w/ a rear speaker. The radio had the separate duplexer. Have the radio wired up on a bench and everything is working. Now just trying to figure out how to incorporate the 8 track. I understand it has to tie into the radio. Can both the tape and radio play at the same time? Does inserting a tape cut the radio out? I am flying blind here but the info you have given will help a lot. Thank you.
