We had some snow today and the traction control went off a couple times while taking off from a stop. Nothing out of the normal and this was with 2nd gear or even 3rd gear rolling stops. When I was almost home, the traction control kicked in again and then an ABS Fault warning came up on the display with the Traction Control Off icon showing. The ABS is not working at all and the same with traction control. I checked and changed the fuse even though the original looked fine. I have turned the car off and on several times and the warning comes up still. Any ideas on what might be wrong? I will take it to the dealer but want some advice so I know what to expect.
