Hey Guys
I got a slight problem maybe you can help with.
When i get on the gas i start getting a popping/loading up sound and hesitation around 4k rpm.
I'm sure the plugs are fouled because they foul out like its thier job in this engine.
So i called the Motor shop today asking about trying new plugs, they said to try a hotter plug instead of the colder ones i use due to it being a 12 to 1 comp ratio.
I just cruise around town, not racing so the rpms never really get up above3k to 4k anyway
He said a hotter plug would burn more of that carbon up like the way a glow plug can handle desiel, which kinda makes sence but scares me about pre-ignition.
They also told me to swap to a MSD 6AL system but i think he assumed i was running stock points not a HEI upgrade(Accel 140005).
Ok so here is the question is this Accel HEI trash or is it fine?
Do i need to and a controll box like a MSD 6AL?
im not sure the Accel super coil can use a external box or not.
And should i try the hotter plugs?
(if you want to see engine spes i have detail listed in the forsale thread under 69 built 455 btw)
Thanks again
Silky58
What year. Engine? Do you have 12V to the positive side of the coil? Try this question on PY forums.
I hve 68 up graded to Pertronix. Had to plce jumper wire behind ignition switch from R1 to R2. HEI need 12 V.
its a 1969 gto with a 73 455, like i said in the post i have full engine details list under the for sale section.
the hei is alrdy on i was wondering if i needed to add a control box, add if i should try a hotter plug.
thx for the reply tho
