Hey Josh,
I wish I'd seen your post sooner. The big question is: what do you plan to use it for?
I looked at the page with the specs for it, and saw "SCFM delivery at 90 PSI: 11.3 SCFM". If you're planning to use it to paint or to run air tools, that's going to be a little "light". You want 15 SCFM at 90 PSI, minimum for those jobs. Otherwise the compressor is going to tend to run "all the time" and that's going to result in "hot" air with a lot of condensation/water in it. The air system you plumb it into is also very important. You want at least 20 feet of line between the compressor and your first delivery point, and that line should be hard pipe - steel is ok, copper is better - and it needs to slope "downhill" back towards the compressor. Purpose being: the metal will help cool the air so the condensation will tend to drop out of it, and the slope will help it tend to run back towards the compressor instead of out through whatever you'r using the air for. If you're going to be painting with it, this is very important as is having a very good moisture removal system prior to your gun.
Here's what I'm using.. Also when you plumb your air system, linclude "drops" that are low points with valves at the end of them so that you'll have places where you can drain the water out of the lines -
here's an example. My air system has three such drops like this - one near the feed for my air tools (that's the one in the previous photo), another at the feed for my paint gun, and a third that's below the point where my compressor connects to the air line. You'ld be surprised to see how quickly these points need to be drained when you're using the compressor a lot on a hot, humid day. It's quite possible to spend as much on your air-line system as you do on the compressor, if not more.
EDIT: There's a guy over on the
Paintucation forums, GaryL, who's a real expert in air systems. It'd pay you to go over there and search out all his posts on the topic. I'm no expert on the topic - everything I wrote above is basically an echo of things I learned from him
When I upgraded my air system last year and put in
this compressor, I followed his advice. It's big enough, but just barely. When I was running the air sander here recently, wet sanding the paint getting ready to buff it, the compressor ran quite a bit and I still had to pay attention to keeping the system drained fairly often.
Another edit: (Just because I don't want you to think I'm being a "negative Nelly"
I used a tiny 2hp portable 110v Campbell Hausfeld for 15 years or more, and ran air tools and everything with it. I had it plumbed about as "wrong" as you can do it, with PVC pipe, because I just didn't know any better. I even used it to apply all the primer coats to my car. I just had to "adapt" - i.e. pay close attention to keeping it drained and also spend lots of time waiting for it to "catch up". It didn't matter for the primer because I knew I was going to sand all that anyway. I only upgraded because I didn't want to be in the position of having put in hundreds of hours getting the car finally ready to paint, then have the paint job messed up (and "waste" all that expensive paint and clear) by a compressor that wasn't up to it.
