I just finished putting an '06 GTO LS2 into my '40 Chevy. Because of clearance problems between the engine and the radiator, I can't use the tube the MAF is attached to. I removed the tube and installed the MAF directly to the throttle body. My question is this... Is there a filter, probably a cone type, that will attach onto the MAF? Or, is this a bad idea? Thanks for any help.
A Pic. of your set-up would be helpful.
There are numerous cone filters available in different sizes, just not sure about the clearance between the TB and radiator. Also, heat soak might become an issue…:)
You can do it, you might need a filter with a 4" id opening. It's a stright shot so no worries on throwing codes.
if you do it that way you are going to get serous heat soak
if you have enough room for a pod filter and the maf
you would have enough room for the standard intake pipe to fit wouldnt you
