1 - 15 of 15 Posts
Discussion Starter #12
RUK and CRUSTY, Very observant! The body IS bolted to the chassis. The front fender is not attached to the wheel well, nor to the crap deflector that goes wheel well to rad support. Also the entire suspension, top and bottom, and front to back is WAAAAY out of alignment, and is all fully adjustable. The camber is probably at +10* right now. I am also sure the rear is not 90* to the drive line/chassis..........everything needs to be aligned and adjusted. Also the Camaro wheels in front sit too far out (need more back space). I plan on getting it "close" when the engine/trans is in, then off to a "good" alignment shop (ha ha).......:cheers Should be fun, Eric
1 - 15 of 15 Posts
