I know what you mean! It was about 3-4 days before I could get mine fixed and it about drove me nuts!! Hopefully it's the same rattle and you can fix it the same as I did.LIVEVIL said:I will do anything to get rid of the sound. Thanks for the write up, I'll be doing it as soon as the rain stops. Don't want my baby to get wet.
Sweet!LIVEVIL said:Got this fixed with the help of you guys. No more rattle
Cool!LIVEVIL said:Thanks so much man. I am now very happy to drive here again
It has 2 or 3 screws and the it will just drop out.tano said:got my new goat... found a new rattle... same one you guys are talking about.
Silly question... how did you get the panel you're talking about off?
yup mine too..about 45 miles...LIVEVIL said:I had no choice but to fix mine and the car had no miles on it at all. Annoyed the sh1t out of me.
Yeah maybe it did just pop out...I was thinking it had screws but I might be mistaken...LIVEVIL said:Once you get that seat slid all the way back, which BTW will take 5 minutes with how slow our seat motors are. Take the underpanel off. Just pop it out towards you from the top and then remove the lower portion. Get into a position that will hurt your back worse than you can believe. Something that even Jenna Jameson wouldn't be happy about. Just bump the under metal cage made up of 3 plates with 10MM bolts, under the steering. You should hear the rattle. I took my bottom plate off, then jammed a screw driver up between the 2 plates inside the dash, This move seperated them enough so that the rattle was now gone. I hit everything with my portable impact gun to make sure it was all nice and tight again. Good luck.
