Has anyone had anitfreeze leak from the hose on the motor? Mine is leaking at high speeds, now my light reads low coolant??? The coolant reservior is full???? I will be taking to the dealer.
Yes, the K&N CAI comes with new plenum, heat shield, and big cone shape K&N.GTO TOO said:Just a quick note. Did you use the K&N oiled filter with your CAI? If you did there is a service bulletin not to cover under warranty the MAF or O2 sensors as a oiled air filter element can poision both. Just a thought.
No leaks here. There is a fairly common problem with leaks from the freeze plug on the front of the passenger side head.heatherGTO said:Has anyone had anitfreeze leak from the hose on the motor? Mine is leaking at high speeds, now my light reads low coolant??? The coolant reservior is full???? I will be taking to the dealer.
