I see that most of these come in the white, presumably to match paint? Can you get them in Flat black and not even try? The black look appeals to me. Also, how hard is it to do the ram air functional route? you need I guese an aircleaner w/foam then some metal stuff for the hood, and finally pull the blocks out of teh scoops? Worth doing?
i bought an aftermarket tach for my 70 gto just for the inside tach mechanism and the outside piece came flat black .I bought it from ames performance.I also installed an aftermarket ram air system and its not that difficult to install,although you have to cut a little of the underhood framing for it to fit.As far as performance,i think its more effective at higher speeds.
