They're both assembly plants, as you know. B in the vin is Baltimore and BF on the data plate is Fremont. I wouldn't think it was possible. Then again, .................. What year?
I checked your other posts, figuring a '65.....
Ift wold be possible if either tag was swapped. PHS documentation will verify. Probably a good idea to check the VIN on the frame (upper driver's side above the rear wheel generally) if visible, and I'd take a really good look at the tag rivets, too.
:agree
Data Plate
PON = Pontiac MI
KAN = Kansas City MO
BF = Fremont CA
BAL = Baltimore MD
Vin Tag
P = Pontiac MI
K = Kansas City MO
Z = Fremont CA
B = Baltimore MD
:agree:agree With the last 2 posts. :)
My initial response was off the idea the OP was asking if that combination of codes was possible "from the factory". I guess I was reading between the lines.
Maybe post a couple of pix of your tags......
