OK, so I've been doing some research. The 9C1 tank seems to be a common swap for those going to an EFI setup. While I'm not there yet, I'm tempted to do a Rochester TBI unit and a Megasquirt in the long run since I can do it with parts I pretty much have here. Anyone done this? What did you think? What did you use for a return line? I have a non A/C car which means I have a "2 line" fuel pump. I'm guessing you "3 line" guys are set out of the bag.
The odder one, is I found pretty much a single mention of using a 9C1 Caprice sway bar in the rear on a Chevelle forum. Has anyone done or measured this? Is it even plausible?
