Hey guys, my 68 gto 400, 4 speed, has began backfiring when I put my foot into it. It is backfiring right underneath me, not at the end of the exhaust. I checked the timing and it is good (14 advance at idle) that is where I have always ran it. It also began surging when coming to a stop. Are these problems related? they both began around the same day. Thanks
Is it only on driver side? You could have a dead cylinder, ignition related. The fuel/air mixture igniting in the header/manifold. Get an infra-red temp gun(very useful), and check the temp at every exhaust port after running the engine for a while. If you have a dead cylinder, it be cooler than the rest. Then check the plug and wire on that cylinder, or cap and rotor.
backfiring
Carb is two years old. Never had any trouble. Its an edelbrock 750. Is there a safe idle setting I can do? I'm not a carb guy. I think the book says 1 half turns from lightly seated. But I haven't tried it
Sounds too lean to me. I'd check for vacuum leaks/carb mixture. Try this: at idle, take the air cleaner off and mist a small amount of carb cleaner into the carb. If it speeds up and smooths out, it's too lean----caused by a vacuum leak or the carb itself.
