If you don't mind be butting in, I limited my upgrade to AC-Delco C5 front pads. Happy with them and zero dusting.Lally said:SSBC has a kit, as does AP racing (supplier for the 14" HSV upgrade)... Baer makes an upgrade now, also "dba" - Disc brakes of Australia.
There is always the upgrades that Harrop and JHP carry
The trick is to do a full car (all 4 corners) balanced upgrade. Just upgrading the fronts can wreak havoc on the ABS system.
Why are you looking to upgrade the stockers (if you dont mind me asking)?
LynmupLYNMUP said:I too am looking for upgrading the rotors to drilled or sloted. Going from 155mph to 60mph tends to suck at fast speeds. I like the stopping power of the stock brakes, just need to rid the brake fade. Where can I get rotors that will bolt up to the stock calipers?
