Anyone out there in GTO land running a set of Pontiac or Edelbrock black die-cast aluminum or steel valve covers?
Would you be willing to post a picture or 2?
My '69 came with a set of engraved Tin Indian aluminum covers and I am tired of the look, so thinking of changing to something different.
These are the 2 options that I am trying to choose between:
https://www.summitracing.com/int/parts/sum-440415/overview/make/pontiac
https://www.summitracing.com/int/parts/edl-4453/overview/make/pontiac
Thanks in advance - much appreciated
Joe
Ok, so I have decided to go with the Summit Racing Pontiac die-cast aluminum black valve covers, as well as a black Edelbrock aluminum breather on one side. My current set up. with the Tin Indian covers, has an aluminum breather on the passenger side and an aluminum oil-fill cap on the drivers side.
So here's my question: can I run 2 aluminum breathers, simply using one of them as an oil fill access when needed? Is it generally considered more 'correct' to use only one valve cover breather? Am I about to create unnecessary problems?
Thanks again everyone.
Joe
