1 - 9 of 9 Posts
on 67 gto with air how is the best way to remove blower motor and whai is the tube attached to blower motor for
thakyou
ss
Not sure on the 67,I know on my 72 I would have to drop the fender well to get to it. The hose is for cooling the motor from fan housing
It takes several small wrenches and small sockets to get it off without removing the fender. On my '64 GTO, there is a bolt at the lower right of the housing (closest to the fender) that is a nightmare. I left that one out when I put it back on.
Did it work?!? I have a ‘67 Lemans with air and 326. I got the five screws out and dropped the blower...onto the valve cover!! Tried some creative language, but couldn’t get the blower out of the hole. Can this be done without pulling the engine first?
No experience with this, but in the diagram it looks like you may want to pull the housing as well, not just the blower motor. I assume the motor hits enough that removing the valve cover won't give you the needed room to drop it.
1 - 9 of 9 Posts
