1 - 10 of 10 Posts
I'm hoping someone can give a definitive answer, as I've been unable to find one in my searching on the BMW/GTO wheel fitment issue.
I'm looking at a set of ASA GT5 Wheels from a 05 M3. It is a staggered set-up. Fitment:
FRONT 18x8
Offset: 40mm
Backspacing: 6.10"
Bolt-Pattern: 5-120 (I know this is what we need, but is 5-120 universal, or, like everything else with the GTO, is there something different that makes it non-compatable?)
REAR 18x9
Offset: +30mm
Backspacing: 6.22"
Bolt Pattern: 5-120
My main reason for asking is that Tire Rack (where I found the wheels in question) seems to offer the best wheel/tire price and I can order them pre-mounted and balanced. If I can run this set-up, I think this is what I'll spring for.
I will be having my Pedders Street 2 installed in the beginning of February. This is the NO drop Kit, so I will retain OEM height.
Will this fit? If not, is there anything that can be done to make it fit? i.e., spacers, etc. I do not want to roll my fenders.
Thanks for the input ahead of time.
Ha! I was so concerned about posting the backspacing I forgot to put that. Thanks. Front are 18x8 and rear are 18x9.
I found 18x9 rears for an 05 330 coupe with 45mm backspacing. Guy at the tire rack says he had a GTO (2006) and that he had BMW 330 ASAs on. Will moving from a 30mm to 45mm backspace make it doable?
I ended up getting the Enki Tuning Rijian Black painted wheels. I liked the look better, they were a tad cheaper, a bit lighter an I an rotate. I have 245/40 Hankook Ventus V12 evos on them. I think my other wheels (aftermarket, but idk what...) were heavy POSs. I could feel a significant difference (plus better rubber helps). The ones I took off were heeeeeavy, man.
I have pics posted under the tread "Enki Tuning...blah, blah, blah"
I can't seem to be able to take a pic that captures how good they look, but I love em. They are listed on TireRack under 2005 BMW 330, if interested.
I'm DDing my Goat for now...if I wasn't, I'd probably be running a staggered. Either way, I can't be happier. Next go 'round, I'm gonna run 255/35s. I have good clearance, so the extra 5mm per side will be good.
1 - 10 of 10 Posts
