1 - 10 of 10 Posts
Brake Booster Vac Line '67 GTO & PCV Grommet
400 CI engine in a '67 GTO.
What does the metal line look like that attaches at the base of the carburetor onto which one fastens the 3\8" hose routed to the brake booster?
There seem to be two options. https://www.npdlink.com/store/?p=catalog&mode=newsearch&search_str=vacuum+line&parent=10000&year=1967
Secondly, where does one get the rubber grommet that secures the PCV valve in front of the distributor mounting location? My PVC is rattling badly because the grommet is like hard plastic.
Banned
I didn't know if you had the tube so I figured I would show the fitting as well, it would suck to get the tube and not have the fitting.
Discussion Starter #10 (Edited)
Grommet here, part #N210A
https://secure.amesperf.com/qilan/Search_Web?order_number_e=NDU0MzI2Mg== &method_1=&method_2=Y&on=Y&search_method=2&cat_rowid=1&search_year=1967&search_keyword=PVC+&sort=0[/url[/quote] Today I ordered a new grommet, PCV valve, brake booster vac line and a few other miscellaneous parts from AMES. Thanks for the link. AMES seems to be good people. This grommet seems to be the unicorn of GTO parts as I could not find it elsewhere. Andrew
1 - 10 of 10 Posts
