At 4,000 miles I spun a crank shaft because I was burning oil too fast and was a few quarts low(this after getting an oil change at 3K miles). They did a complete engine rebuild.
At 5,500 miles, I changed my oil for the first time after engine rebuild.
At 7,400 miles (today), I checked my oil level to make sure everything is okay, I was not getting a reading on the dip stick so I decided to change the oil again. When I drained the oil, only 1.5 quarts drained (this is after putting 6.5 quarts in at previous oil change). Is it just me or is 5 quarts way to much oil burned in 2,000 miles. I have not seen any leaks on my driveway or garage floor, so I know it's not leaking. What would be wrong with my engine rebuild from 4,000 miles that would cause the engine to burn oil so fast (bearings getting too hot).
Any help would be great, obviously i'm going to take it to the dealership so that everything is documented in case this engine goes again.
