Yea I did that on Saturday to reset the SES light and clear the code. Ive already checked all the MAF connections. It set the light almost a month after I installed the CAI.johnebgoode said:Disconnect the battery for 30 mins. This will let computer wind down. Make sure all your wiring for MAF is connected properly. Check for bent or mis aligned pins in the connector ,reconnect battery.
hmm are we sure it's the CAI then? I mean, the MAF is there to determine how much fuel to send to the cylinders, not complain when it's getting more air than stock. If they all did that, dry nitrous kits wouldn't work.BlownGTO said:Yea I did that on Saturday to reset the SES light and clear the code. Ive already checked all the MAF connections. It set the light almost a month after I installed the CAI.
.....you do realize that's a K&N filter on the end of that New Era cai...... if the filter is "over-oiled" then you may have issues, but, as soon as you reset the light it would trip it almost immediately. GM has a tsb on the K&N filters, maybe you service manager was getting confused. No biggie.....:cheersSoGaGTO said:he told me one of the brands would leak oil and cause the check engine light to come on. I believe it was the New Era CAI but I'm not sure. He said they haven't had any trouble with the K&N CAI.
GTODEALER GM has a tsb on the K&N filters said:Does this TSB include stock K&N replacement filters? If so, what does it entail? Just curious......I recently purchased a K&N replacement filter for the '05.![]()
Yep, it's just for stupid people (as in the K&N people who oil them before shipping) that over-oil the hell out of the filter.PHOTOGOAT said:Does this TSB include stock K&N replacement filters? If so, what does it entail? Just curious......I recently purchased a K&N replacement filter for the '05.![]()
And there is the best thing said thus far. It's supposed to be a COLD air intake, remember?QSGTO said:If you want to run a CAI, route your intake tube below the radiator where the heat is lowest, since heat rises.
Hope this helps
Danny
Yep, and I know I'm gonna get flammed for this, but, I hate them both. If it were me I'd buy a K&N or fabricate one to go through the fender.Starrbuck said:Have you seen version 2 of the New Era? It's on their website now...
I just ordered the LPE.![]()
