Camshaft and crankshaft question?
I need to know if this lunati camshaft will fit into my stock 1968 lemans with a pontiac 350 engine without any modifications. i also need to know if a pontiac 400 engine crankshaft will fit in a pontiac 350 engine.
http://store.summitracing.com/defau...earchinresults=false&N=0&target=egnsearch.asp
u might need to copy and paste that but if dont want to heres the specs
Brand: Lunati
Product Line: Lunati Bracket Master II Cam and Lifter Kits
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,800-5,800 RPM
Intake Duration 050 inch Lift: 230
Exhaust Duration 050 inch Lift: 230
Duration at 050 inch Lift: 230 int./230 exh.
Advertised Intake Duration: 292
Advertised Exhaust Duration: 292
Advertised Duration: 292 int./292 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.490
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.490
Valve Lift with Factory Rocker Arm Ratio: 0.490 int./0.490 exh. lift
Lobe Separation (degrees): 110
Intake Valve Lash (in): 0.000
Exhaust Valve Lash (in): 0.000
Computer Controlled: No
Lifters Included: Yes
Lifter Style: Hydraulic flat tappet
Brand: Lunati
