The Morano dead-pedal mounts to a curved surface of the center console so can not be directly used on the straight kick-panel by our left foot. That's why we did not get one to start with.
I've heard rumors that this component was dropped as a production item at the last minute. May be confirmed because the initial '05s don't have them.
If you don't want to wait its not that hard to build your own (post above). I made one the other day but did it a bit different. I used a 2x4 with one end cut at a 45 degree angle. I nailed a 1x2 along the front surface, covered it on 2 sides with black carpet scrap I had (could have painted it black instead and install an alu plate to match the pedals), and placed hook velcro along the leading edge of the 1x2. This way, You don't have to take up any carpet or take off the side panel. The 1x2 provides an inset to allow for the ridge in the floor carpet running near the kick panel - I just positioned it on the floor, pushed back, then pushed it against the kick panel so the hook material would hold (it actually sits on top of the floor mat). You can't tell it is even there because of the black carpet. I've taken it out twice to cut some off the back side - position of the surface has made a big difference on how my leg feels. I've taken off about an inch so far and it feels pretty good now. I'm sure everyones preference would be a little different, so even if you had a template you would have to customize it. I'd even use this method initially to get the position right then install it underneath the carpet if you still desire too.
