Trying to get trans away from bellhousing to replace throw out bearing on my 2006 gto. Seems to be stuck on the guide pins. Tried to use a chisel that wouldn't budge it. Then tried a putty knife to no avail. Tried 3ft pry bar on rear of trans. HELP
Welcome !!
yah I am a '68 69 guy and my cars all have muncies
I have not had that issue b4
but
xxx2 on 1 more bolt .... unless you have some kind of corrosion going on
be carefull under there .... I dont wanna sound like your mama .... but ...
https://www.google.com/search?q=2006+gto+transmission+bolt+location&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjA46GFk-feAhWQGTQIHYg6BeEQ_AUIDigB&biw=1067&bih=691#imgrc=yEi7e6yctp1oMM:
I am sure you have google it already ....
theres alot of great help here ... but googles your 2nd best friend after us .............. :)
I put up a link to the factory shop manual here: https://www.gtoforum.com/f2/factory-shop-manual-04-06-gto-132603/
You can download the whole thing or just the section you want.
It will show you a drawing of the trans - bell housing and you can review and then sort out if you have the topmost bolt out. Which I do not think you do.
You are also going to want to buy the Tick performance slave cylinder / throwout bearing with the remote bleeder. Really. I mean - REALLY.
