Thank you for the reply. There is no julian date by the model number. Is the number on the base plate the date code? Also wondering if the date code could show what set up this was originally put on in 1969. Any info is appreciated.
From 1966 thru the late 1970's Carter Carburetors was contracted to build the Quadrajets for GM, Sometimes, no Julian Date indicates the carb was built by Carter and not Rochester. As far as the set up here is a breakdown on the code;
702 = 1960's
9 = 1969
2 = Quadrajet (4 bbl) 49 state Federal standards
7 = Pontiac
3= Manual Transmission (odd numbers are manual transmissions and even numbers are automatics)
Post some pictures if you can,
