I just did the cd auxiliary input mod on a whim, and holy shart this is awesome! honestly the quality is perfect, no problems what so ever, the hardest part was routing the chord when i was done.. If you have not done this mod, wtf are you doing with your life. :party::party::cheers:party:
I did it to my Z06 a few weeks back. Def awesome and sounds great. I have what sounds like a small group loop when I use the aux though.
what do you mean by small group loop? it is either sound from the track on your cd, or it is simply a bad solder connection. if everything is done perfect, the sound should be perfectly crystal. Did you use the built in ground, or some place else?
If you have not done this mod, wtf are you doing with your life..
What many have done. I removed the obsolete factory stereo and replace it with something that is more up to date...you know; something that has an aux port built in, usb, plays mp3's, and no 6 disc changer since that's really not needed anymore.
cool
Typo. Its a ground loop. I just grounded to the cd player case.
Wish I could do that but C5s can't hold a 2 din without buying a whole new aftermarket centre console.
