GM A Bodies/ Pontiac GTO's have a ton of room for improvement in their suspensions. Putting aside personal preferences for ride height and quality, if you want a car that:
It's important to note that there are two ways tubular control arms accomplish these improvements:
I'm always going to recommend Global West, because they're a USA company using USA parts, they answer the phone, and the owner is a GTO owner, who tests his products on GTO's. That being said, I also use and love UMI... and there are many other terrific companies out there, who I dont personally have experience with.
CRITICAL: YOU WILL FIND LOOK-ALIKE TUBULAR CONTROL ARM SETS ON EBAY AND AMAZON, AND ALTHOUGH THEY MAY BE CONSTRUCTED WELL, THEY USE DANGEROUS AND INFERIOR HARDWARE. THEY ALSO MAY NOT CORRECT GEOMETRY. THESE KITS WILL LIKELY IMPROVE A STOCK CAR, BUT YOU MUST REPLACE THE BALLJOINTS AND HARDWARE WITH QUALITY PARTS BEFORE USING THEM.
Even with having to replace the balljoints and hardware on the no-name kits, they'll still be cheaper than the big name stuff, so this option shouldnt be ignored if it fits your budget. Many of our forum users have gone this route and they are happy with the results.
What kind of bushings do you need/ want:
You will need to verify year specific parts and fitment.
www.summitracing.com
- Handles better
- Brakes better
- Steers better
- Has no wheel hop
- Has increased traction
- Recovers quickly from burnouts and loss of control
- By eliminating flex. Most welded, tubular control arms will eliminate the flex of the factory arms.
- By changing geometry. NOT ALL tubular control arms have corrections built into them.
- Rubber = OEM style, best ride quality, worst feedback and response.
- Poly = Harsher ride, improved response and feedback.
- Delrin Bearing = Zero bind, firm ride, best handling, traction, and feedback there is.
- Spherical Bushings = Maximum articulation for centering the diff and keeping things square to the road. Can have spherical on the rear upper and lower arms but only on one end of the arm! Consider spherical for the frame side of the lower and the diff side of the upper.
- Most of the Global West stuff will work with stock or lowered springs and spindles, but I cant speak on the other brands.
- Yes, you will need an alignment afterwards.
- You will need a coil spring compressor.
- There is a hole in the front-upper-coil-spring pocket. You can drop a bolt though it and rotate the new coil springs to stop at it. Remove the bolt after the job is completed.
- Rear frame supports, such as those used on factory GTO's, can be purchased VERY CHEAP, and since they use the control arm bolts to mount them, you should seriously consider this option, if replacing the rear control arms. They dramatically improve handling and reduce wheel hop by traingulating the rear frame section.
- If you have headers, you may have trouble installing the front uppers. This will require you to either lift the engine, or remove the factory pressed in alignment bolts.
- If you have headers, you will likely have to wrestle with the front-lower-driverside, rear bolt.
- If the car sits too high in the front after replacing everything, you may need to add a 1" spacer to the rear springs.
- Although not part of the control arm swap, you might also consider No Bind Rear Shock mounts and new sway bars.
- Coil Springs and Shocks should be changed.
- The entire job can be done on your back in the driveway, with a floor jack. It will take the day to do an entire car, but if you have good stuff and are prepared, it's easy, straight forward work.
1967 PONTIAC GTO Global West Suspension CTA-42L Global West Suspension G-Plus Control Arms | Summit Racing
Free Shipping - Global West Suspension G-Plus Control Arms with qualifying orders of $99. Shop Control Arms at Summit Racing.
1967 PONTIAC GTO Global West Suspension CTA-42A Global West Suspension G-Plus Control Arms | Summit Racing
1967 PONTIAC GTO Global West Suspension TBC-4 Global West Suspension G-Plus Control Arms | Summit Racing
UMI Performance 4016-B UMI Performance Rear Non-Adjustable Upper Control Arms | Summit Racing
Free Shipping - UMI Performance Rear Non-Adjustable Upper Control Arms with qualifying orders of $99. Shop Control Arms at Summit Racing.
UMI Performance 4034-B UMI Performance Solid Rear Sway Bars | Summit Racing
Free Shipping - UMI Performance Solid Rear Sway Bars with qualifying orders of $99. Shop Sway Bars at Summit Racing.
UMI Performance 4035-B UMI Performance Front Sway Bars | Summit Racing
Free Shipping - UMI Performance Front Sway Bars with qualifying orders of $99. Shop Sway Bars at Summit Racing.
UMI Performance 4049R UMI Performance Stock Height Springs | Summit Racing
Free Shipping - UMI Performance Stock Height Springs with qualifying orders of $99. Shop Coil Springs at Summit Racing.
UMI Performance 4049F UMI Performance Stock Height Springs | Summit Racing
No Bind Lower Rear Shock Relocation Mounting Brackets | 1964-1977 GM A-Body: Chevelle, Malibu, GTO, etc.
No Bind Lower Rear Shock Relocation Mounting Brackets for the 1964-1977 GM A-Body. Rotates the bottom of the rear shock to eliminate bind.
www.spohn.net
Global West Suspension TS-47 Global West Suspension Rear Frame Supports | Summit Racing
Free Shipping - Global West Suspension Rear Frame Supports with qualifying orders of $99. Shop Control Arm Reinforcement Braces at Summit Racing.
