Hi, new to the forum...
Just wanted to know. When I start car all the lights start (brake/ abs/ check engine etc...) but then after a bit they all go off.
I've noticed thought that if I turn the key to the ignition and then turn it off and take off the key the check engine light stays on for about 4 secs then it goes off. Is that normal?
All indicator lamps come on when key is turned to on, this is a bulb check. If these lights stay on for a few seconds after being started it is normal. If you had a code it would stay on.
