It usually end up hearing it when i am on the freeway. It sounds like it might be what ever makes the blinker noise bouncing around. Has anyone else heard this? Any ideas?:confused
I had the same problem. It turned out to be the lower dash panel mounts (under the streering wheel). I took it apart and used a small amount of grease where there was contact to the main dash panel.......Fixed.
I had a similar clicking rattle under the dash. When I took the panels off below I found a cross member with two thin peices of metal. I put non-firction tape on them so that they would not touch together. The noise went away.
This noise is on a 2006. The 2004 that I had was rattle free.
