1 - 15 of 15 Posts
clock
Took mine apart and cleaned it. Looks to be original, and for a car clock, the sweephand will hit the 12th hour exactly when the music chimes for the hourly news on the radio, even after a few weeks of the vehicle not being started. They knew how to build 'em back then! :cool
Hello guys,
is it possible to change / remove the clock without removing the complete dash ? (Le Mans 1968)
regards: Peter
The clock was a Factory and/or Dealer option and can be removed without taking the dash out.
See your 1968 Service Manual for the outline. If your car has AC it's a bit more involved but possible.
Hi Peter
I recall doing it many years ago without pulling the dash. Helps to have small hands.
Best to have a 1/4" drive ratchet, extensions, and 1/4" socket. Remove the drivers seat for more room.
Reinstalling is more difficult than removal. The factory notched the upper screw holes in later years to make it easier.
Thanks,
I'll try this next winter.
First of all, I'll convert my (spare) clock to a quartz clock.
For me in germany, it's always the problem with the high postage.....also for small parts. :cry:
These days, I made a km/h sticker for the speedometer (because we in germany need it).
I stand corrected. I read the Service Manual and it appears you can get it out from the back of the bezel without removing the dash. I don't know if I would have enough room to get my big hands up and in there.
Here is a picture of the back of the dash bezel. You can see the dummy filler panel used when no tach or clock is used - its on the left side. This gives you an idea of where and what size the small screws are that will be needed to be removed for the swap/installation.
I have small hands, and all the tools.
But first of all, I need the quartz conversion kit and the wiring (two bulb sockets) for the clock.
So, if someone have the wiring for sell, please let me know....;)
thanks, Peter
thanks, Peter
Don't even waste your time looking for a used wiring/bulb set-up. They reproduce these new. I purchased one when I bought my clock from The Parts Place. Parts Listing Directory
O.K., if I don't get a wiring harness till winter time, I'll buy it new.
(sometimes I find parts here in germany, noone knows where they are from. Last month, I get an orig. new Delco voltage regulator for 20 €....)
1 - 15 of 15 Posts
