My clutch linkage is hitting the starter solenoid.
The linkage is from a 1964-67 Chevelle (ebay purchase)
Starter is a late model 1975, that was in a 350 Pontiac from a 1968 Firebird.
Are the earlier starters different ?
Ken
ahhhhhhhhhhh
bummer
fairly sure you need the a body PONTIAC bell crank aka z bar
chevrolet s the starter is on the passenger side ...........
so the design is different ...
As far as I know Everything chevelle is different ... from the pedal swing pin on the chevy pontiac has a bolt thru the pedals ...to the push rod end sizes and shape to the z bar cimentions
fit ?? yes ......kinda .... correct NO
Scott
youlle need the z bar
the push rod thru the firewall
the adjuster rod all for the pontiac..
then
you may need to pull the clutch pedal to modify the
the push rod hole to fit from chevy to pontiac....the arm off the clutch pedal.. its hole ..
think about where the rod meets the z bar now .... its got to move over an inch on the pivot tube
from block to frame
try and use the same push rod thru fire wall and all the angles will be jacked out of whack...
sell what you have to a chevy guy and buy all the right stuff
pedals with circles stamped into em and not horizontal lines.... and a pivot bolt not a pin
