Hi gang, long time no post.
I had my motor re-built quite a few years ago (2012). It sat till I finished my resto in 2015. Strong running, no leaks, plugs burning clean. I have been getting considerable lifter tap from the left bank and was preparing to do a cold engine overlap adjustment using the standard “engine off” procedure. At 0 TDC, #1 rockers fully relaxed, I noted that I could compress the lifter by hand on #1 intake, #3 exhaust but #5 and #7 intake are fully pumped up.
Is this normal?
68 400, 30 over, Comp cam, stock rockers, forged pistons and rods, balanced, port matched....the works.
Motor not started in about two weeks
I cranked engine (plugs out) for about 10 seconds before pulling valve cover
Only 2600 miles on the motor
Let me know what you think.
Is this normal?
