WOW please help I want to replace the gear box on my 1970 GTO so I ordered a Cardone 27-6509 2 1/2 to 3 turns lock to lock. Steering box input is a 13/16 in. 31 spline.which says it is a perfect match ! my problem is I am trying to find the right Rag Joint or Steering coupler for the Cardone 27-6509. Does anybody know what one I need to order? I think it is the Lares 201 Help Please. :surprise: Found this Lares # 201 Exact Fit for your 1970 Pontiac GTO
;10:1 Fast ratioNew; For 13/16" 31 spline input shafts with flat and 3-1/4" OD steering coupling assembly.
Rock Auto lists the below for 1970 GTO. Looks like 201 is what you need
LARES 200 3.25" OD Info
For 3/4" 25 spline input shafts with flat and 3-1/4" OD steering coupling assembly.
$18.30
Add to Cart
LARES 201 For 13/16" 31 spline input shafts with flat and 3-1/4" OD coupler. Info
That is what I thought :surprise: and I think that I will order a Lares 201 but one place says 31 spline and another place says 36 spline and I bought the Cardone 27-6509 gear box and it calls for a 31 spline
https://www.speedwaymotors.com/Lares-201-Power-Steering-Coupler-1967-79-Nova-1967-76-Camaro,120567.html
https://www.rockauto.com/en/parts/lares,201,steering+coupling+assembly,7418
https://www.rockauto.com/en/moreinfo.php?pk=31200&cc=1256385&jsn=408
I hope it is a 31 spline and thanks for the reply :cheers
