Hi All,
I have 1970 GTO RAIII with oem heads, 4 core brass radiator. I filled it up with distilled water and one bottle of "wet wetter" and i would like to add a bottle of "Lucas super coolant," but their website said:
"For street vehicles requiring freeze protection, add 1 bottle to 50/50 mix. For racing and high performance applications, add 2 bottles to straight water coolant for maximum temperature reduction. DO NOT use distilled water unless mixed with 50% antifreeze."
I am not worry about the antifreeze cuz the temperature where i live won't go below 38 degree in the winter. so can i add it? Or should i put new distilled water or tap water with 2 bottles?
Recommendations
Hi All,
Recommendations
You want to only use distilled water as tap water will have minerals in it that cause the problems with a radiator. I would not use straight distilled water. Use a 50/50 anti-freeze mix. The anti-freeze is not necessarily about cold temps and freezing. It offers a higher boiling point so if your engine runs hot at some point, boil over will occur at a higher temp. You also have the anti-corrosion benefits of the anti-freeze.
I used the 50/50 mix in my '68 Lemans with the 4-core radiator and added the "wetter water" to that. The wetter water did seem to drop the coolant temps. As I recall, the wetter water also helps as a water pump lubricant.
So my recommendation would be the 50/50 anti-freeze mix and 1 bottle of the wetter water additive. I would not use just distilled water and the additive. May be fine for the race track, but I don't think I would go with it on a street car.
You can take what Jim said to the bank. I run the same combo in my Pontiacs, and have for years and years. No worries.
