1970 pontiac 350 hooked to a th350. After replacing the head gaskets cars been doing great still working out the kinks. Took it for a run the other day about 5 mile round trip, the last light before my turn I was stuck at the light for about 5 min it started to struggle idling then died from the struggle to death it was about 10 sec. It fired right back up then died this is about 3 times finally was able to get it in gear and throttle it and got home with no more issues. Temp stayed around 180 where the t stat is set at idle it holds oil pressure at 25ish under load it goes as high as 60. When parked hot it drips coolant from the back down the k member about a cup or more then stops. I am tempted to point my finger at a warped intake manifold (it was welded after being cracked trying to take out a plug bolt that was locktited on) or a freeze plug in the back. I cant find and puddles or obvious place the coolant is leaking from, anything I can do short of pulling the intake to diagnose?
Thought about the stalling, it might need gas it was showing a quarter tank but my gauge might be wrong? it was the first time other then when the head gasket failed that it stalled out in traffic...I'm more concerned about the coolant leak for now, baby steps...thanks for any input you can offer no idea what I'm doing :crying:
