1 - 9 of 9 Posts
RIP (12/27/60-7/18/15)
Awesome, thank you guys.............and Kat!
looks like a job for my BFH!!!!
TK
:cheers
Are there supposed to be spacers between the header panel and the and the core support bolt down points?
thanks as always
Ideally, NO....You might want to talk to Randy (05GTO). I beleive he replaced the rad/sup in his GTO with a repro unit. Something to consider, if it fits your budget.....E
there should be bushings down where the radiator support bolts to the frame I believe, but otherwise no. but yea, you are a little bended. my channel on the bottom is open down and not up, but otherwise is identical to the one "likethat" posted.
Your support needs to look "likethat"'s. I would get another one.....you'll be fighting body alignment issues for days with that one. Or, borrow a straight one to use as a comparison, remove yours, and blacksmith it back into shape. You need a good one to use as a reference, though, IMO.
1 - 9 of 9 Posts
