1 - 11 of 11 Posts
66 with WS engine. Owners manual says 7 quarts with filter change. Dipstick says 5 qts (can not verify dipstick is the correct one). Pontiac Shop Manual say six qts. Which is correct?
As far as I know, most of the pontiacs from the “muscle car” era take 6 qts. My 68 GTO takes 6. I would fill it slowly and keep checking the stick. I don’t know if an oversized oil pan was an option on any of them.
Interesting. My '68 manual states 5 quarts in the pan Plus 1 quart in the filter for a total of 6 quarts. My 1966 AMA 389 engine spec says 5 quarts -pan, plus filter which is 1 quart for a total of 6 quarts. Chilton states 5 quarts plus 1 for the filter for a total of 6 quarts.
All the V8 Pontiac cars I had used 5 quarts plus 1 in the filter for 6 quarts.
Here is another thread on the same question- https://www.gtoforum.com/f50/oil-type-capacity-20669/
:surprise:Amazing how convoluted all these manuals/books are.
1966 AMA TEMP/LEM 6+
1966 AMA GTO 6+
1966 FACTORY SERVICE 5+
1966 MOTORS 5+
I think its safe to go with the consensus of 6
1966 AMA GTO 6+
1966 MOTORS 5+
Interesting.
I do not have the AMA Spec for year 1965, but, my AMA Spec dated 9-2-65 for year 1966 GTO clearly shows 5 quarts plus filter where your states 6 quarts plus filter.
Looking at the 1964 AMA Spec for the Lemans/GTO Option, it also states 5 quarts plus filter.
The 421 Super Duty used a 6 quart pan plus filter.
I have seen this in the specs on the Plymouth Fury. Sometimes they will use the previous year specs on a current engine/car that is still in production. Even options are listed for the new up and coming year and never made available. I suppose that the car specs may have to be submitted at a certain time frame to the AMA and to meet these time frames, they may use some previous engine data to fill in the blanks for the current model engine.
I can also see someone not paying attention when they write the specs and did not notice or understand the fine print "less filter - refill (qt.)"
The pan got changed around 1968-69 to a lower capacity. (Has a drain plug on the side instead of at the rear). My '65 389 holds 6 quarts loaded for bear, and my '67 GTO with it's original engine, pan, and dipstick holds 7 quarts. Always has.
Interesting. The 1967 AMA specs do indeed state 6 quarts plus filter. Looked at the 1968 AMA specs and it goes back to 5 quarts plus filter.
Is the '67 pan unique or are the AMA specs unreliable? My Factory Service Manual for 1968 also states 5 quarts plus filter. :confused:
The owners manual says 7 quarts capacity for the '67. Pan looks identical to my '65's pan...but I never measured the capacity off-car. The 389 in my '65 is a non-messed-with engine I bought off a buddy for $150 in 1980. It was the original engine in his '65 GTO, and my rebuild was it's first....so the oil pan, dipstick, windage tray are all oem. It holds 6 quarts with the short filter, 6.5 with the long filter. The 400 in my '67 is original to the car and had never been opened until I overhauled it in 1988. Same story---all original parts, and a 7 quart engine. My best friend's '67 back in the day was also all original and was a 7 quart engine. I've never had a '66 with the original engine, so can't comment. If I remember, though, all of my '66 GTO's had 6 quart capacites, total. In '68, everything changed. I have never owned anything newer than a '67.
1 - 11 of 11 Posts
