So i have had a few small problems with my GTO that are more frustrating than anything.
The minor problems are/were:
Gas door won't stay closed
Glove box won't close
Passanger seat lever is loose
The shifter shakes and makes noise
I took it in to get the top two delt with but after being told that it would have to be in all day to see what needed to be ordered and then waiting for the parts said screw it and dove into them myself.
The gas door was easy the little metal clip slides in and out for adjustment and it work fine again.
The Glove box was a little more difficult but not bad at all. I took out the whole glove box and disasembled it. The latc mechanism came apart after the roll pin that holds it together slid out. I had noticed over time that is was getting lower and lower and after i fixed it i realized that it was because the pin was coming out. After figuring out how it went back together i reasembled everything and it works like new again.
I'm going to take it in to fix the seat lever and see what they can do on the shifter. Has anyone else experienced these problems?
