I grabbed this rebuilt 120A CS144 at the junkyard out of a '90 Caddy Deville. This is going in my 68 GTO clone with idiot light for the GEN. The '68 has a DK BLUE and BLK SGL WHITE coming off the stock alternator which head for the voltage regulator (which will be bypassed).
I found this from the CS130 service manual:
Unlike other charging systems which have three wires connected to the alternator, the CS-121 and CS-130 may be used with only two wires connected to the alternator. The output wire to the battery positive, and an "L" terminal wire connected to the charge indicator bulb, or to the resistor, or to both.
Also found:
One wire will connect to the output post on the rear of the alternator and the other will be connected through a dash light or to a switched ignition source.
Which wire is the charge indicator bulb or the resistor on a 68 lemans? Is it the DK BLUE or Blk/White? Is it possible to get the GEN light working with this alternator?
Also found:
