Their is a bolt in the way of me chaning my oil< the shop i went to wants to take my car for 3 hours, loosen the bolts around it and turn it ?? do not understand? then drain the oil. MY QUESTION: Should i do this myself? Should I give it to them? I understand it, tht if they turn it from the original instalation it has lost the original warantee, I also have been told from the original shop that installed it, it was quiite easy!!!!!! I am 5 hours away and i am not able to or nor do i want to put that many miles on my new pro charger ( over what the break in period is) which is about to be over its break in miles to go back to the original guys. I WOULD JUST CHANGE IT, BUT I HAVE A ALLEN WRENCH BOLT IN THE WAY OF ME RELEASING THE OIL RELEASE BOLT!!!! WEIRD I THOUGHT. BUT YOU KNOW THE GOAT IS WORTH IT..
I NEED SOME HEL GUYS I WILL STAND BY FOR YOU ... SO I CAN MAKE MY CHOICE. ABOUT WHAT TO DO...
I don't have any experience with Prochargers but I don't think you're going to void the warranty just because you turned it from it's original installation location. If turning it isn't going to cause harm to the unit how will it void the warranty? Makes no sense to me. I say turn it, drain the oil then turn it back to the original position. Save yourself some money and do it yourself. Good luck.
