I am curious to know whether any of you northern members plan on using your GTO as a daily driver in snowy climates. Any concern with having trouble on snow and ice covered roads? The high power engine with rwd layout normally would not be too conducive to those conditions, although it does have decent weight and traction control.
Also, has anyone seen an official minimum ground clearance figure for the GTO? I cannot find any official ground clearance numbers online.
Finally, how does the traction control operate on the GTO? Is it simply a system that cuts power to the wheels when they slip or does it use the braking system?
Thanks!!
Thanks!!
