is your pad good ?
if not
pull hard but not hard enuf to bend the other side thats still clipped in
I have bent alot of the in dash clips b4 pulling 68 pads
ac or non ac
If you have an A/C dash BE CAREFUL pulling the dash from the clips. The clips are different from the non-A/C dash and are unobtanium
Thanks for your help. The Pad is in excellent condition. I need to remove it to replace the convertible top switch. I managed to get a flat blade screwdriver in the slot next to the pin and released the pin. The driver side pin was more difficult but the same method worked.
