Former Super Moderator
Welcome to the forums.
I'd say you have some wires crossed as I see the front marker lights lighting up too. Probably have the brake light and running light wires connected backwards at one of the taillights so when you step on the brakes it's back feeding to the dash and front lights.
Thanks Rukee. I actually went out during lunch and put incandescent bulbs back in the tail lights and it works normal now. I'll chalk it up to needing load resistors even though the bulbs are supposed to have resistors built in. So I have two load resistors en route. Hopefully this solves the problem so if someone else runs into this they'll know what to do.
Well just installed the 6 ohm load resistors and still having the same problem. So the incandescent bulbs will go back in. Having the LED tail lights just isn't worth the hassle to keep messing around with it.
not really. Since I went with the black and clear depos with no red in the tail I was just wanting it to be clear when the light wasn't lit instead of the red of the bulb lens causing there to be some red. I contacted superbrightled today and they said my issue is common with non CAN Bus vehicles using CAN Bus lights, so apparently our vehicle won't work with this type of bulb even though they list it on their website.
bump** sorry to bring up an old thread, but iam having the same problem with my 06
