Hi -
I'm trying to figure out what block I have.... On the ledge, passenger side behind the last cylinder (under right side of distributor as sitting in drivers seat) I found the number 9790071. On the front of the block, I found stamped YC.
So after a ton of reading, I did a lookup here: Pontiac Hunters - Pontiac V8 Engine Codes
Best I can tell, it's a 400 block out of a 68 or 69 B-body. (See attached screen grab)
So what I'm left wondering, and what I hope someone here can chime in on:
- Do you agree with my assessment that it's a 68 or 69 B-Body based on the numbers and stamp I found?
- If it is indeed a 68 or 69 B-Body 400, is there any way to tell what car it came from?
Any input would be great - there's a TON of info out there, some conflicting and I'd love to figure out the history of this block.
Thanks!
Welcome to the Forum. To narrow down what year, you're going to need to look back by the distrib hole & look at the alphanumeric date code. "071" 400 blocks wre indeed cast for both '68 & '69 model years of common 400 Pontiac blocks. The YC coded 400 was very common in '68 & '69 models, as it was the base 400 2bbl code for 400/auto Catalinas. YC or YE coded 400 2bl were also used in '69 Executives. Nearly all Catalina's & '69 Executives, had the 400 2bbl & matching T400 auto. Very very few of these entry level B series slipped out of the factory in '68 with the base 3spd manual 400 2bbl engine. The base engine for a '68 Bonneville is the 340 horse 400 4bbl with small valve ('68 model) 15 heads. The base engine for the '69 Bonneville was the YH coded 428.
Below is a link to Wallace Racings engine code list, it's 99% complete & correct. I surfed the Pontiac Hunters link you put up & noticed quite a few errors. The Pontiac Hunters list also does not list the cyl head(s) originally used on said engines by cyl head code. Hope this helps.
Wallace Racing - Engine Code Charts
Great info - thank you!
So, here's what I have now...
- Number on drivers side of distributor is K157 - I have this as November 15, 1967
- Block number is 9790071, YC - that would be 1968 or 69
- Cylinder head is 15 - the "1" and "5" are separate, not positioned together
- Cylinder head has date stamp K217 - I have this as November 21, 1967
Since the date code on the block is late in 67 (Nov) and the date stamp on the head is also November, can I safely assume that the block and head have been together since birth and that they were originally in a 1968 full size?
Looks like a 290HP 2bbl from 1968... See attached from Wallace...
Thanks again!!
Thank you so much for pointing me in the right direction. It's a new ride for me and I have a list of about 10 things I need to post.... :) At least now I know what the block and head is. Now, for the rest of the million things.....
Thanks again -
