As SAND noted, the big difference between the 66 and 67 GTO is the engine: The 67 was the first year for the 400. '66 was the last year for multiple carbs (Tripower), and the Corvette was the only GM car that was allowed multiple carbs after '66. '67 was the first year for the 750cfm QuadraJet carb, and the H.O. 400 engine cranked out the same 360 hp rating as the 389 Tripower from '66. Along with the bigger engine came a better automatic tranny: the Powerglide 2-speed was discontinued after the '66 model year and the GTO received the Turbo 400 3-speed automatic in '67.
Changes from 71 to 72 were mostly cosmetic: The wire mesh grill from '71 was replaced by a deep-set plastic grill in '72, and the GTO received fender air extractors. 72 marked a further decrease in performance, as the standard 400 engine dropped from its 300-horse rating in '71 to 250 horse in '72. The 455 H.O. from '71 (rated at 335 horse) was continued into '72, but dropped to 300 horse. 2 of the rear axle ratios from 1971 were not continued into 1972: You could not get a 3.90:1 or a 4.33:1 Limted Slip axle in '72. In spite of lower power numbers, the 72 GTO is actually a very nice driving car: It's smooth, handles well, and it actually stops.
