Doubtful, given they're not making them anymore!lotaguts said:I wish we could convert our goats to DOD wondering if in the future someone will do it.
From my understanding of the DOD system the computer locks the exhaust valves shut and then intake valves to 4 of 8 cylinders. As one compresses gas, it is offset by another expanding. If it were to change while in DOD mode, it would probably cause some problems because of the lack of equalization then. I don't know if every cylinder is equiped with the valve solenoids that make this possible either.fergyflyer said:LS2 does not have DOD in the C6 or the CTS-V. No plans for it in 2007 either. 2008 is when the new LS3 should be available. It will have DOD and 6.2 liters with 450-475 hp. From what I have heard the Z06 will get a new engine also that will be called the LS9. It will have around 600 hp and there will be a supercharged version with even more power.
To answer the question, no DOD doesn't cause un-even engine wear. The computer alternates periodically which cylinders are deactivated to maintain an efficient operating temperature.
Obscessing again???enjracing said:wish we did.
