Hi - My vacuum advance was not exactly working right, and i needed to install a curve kit, so I took a part my distributor (a first for me). After opening, it seems that the breaker plate was seized and not moving, so vacuum advance was not doing anything. I seem to have figured most of it out, but have one question related to lube location, could not really find answer anywhere on web. I think i need to put some grease in the channel i highlighted below in the attached image, it looks like it has holes that the grease will drip down and keep everything lubed up. Is that right? I should load some grease in that channel? I've got some red tacky grease with a 540 degree drop point, so think that should suffice? As always, thanks for all your help.
