I recently purchased a 1966 YS 389 block. I want to eventually purchase a tri-power setup for it. Since it did not originally come with the tri-power setup, I just want to make sure this is feasible before I start collecting parts up.
Thanks for your time!
:cool: All the Pontiac BLOCKS are externally similar (the cast-in engine mounts are different on some models). There are two versions of Pontiac HEADS: those with the run-of-the-mill "D" shape exhaust ports and those high-performance versions with the "O" shaped exhaust ports.
As long as your INTAKE MANIFOLD matches up with your HEADS you're okay. So, YES, there shouldn't be an issue putting a tri-power INTAKE on your engine.
Tiretread, there is NO difference between a '66 YS block and heads and a '66 WS block or YR tripower block and heads, except for the tripower intake bolted to them. Direct, factory fit, and guaranteed to make the car scream. Go for it! A '66 tripower unit will bolt onto any '65-'81 Pontiac engine except the 301.
Thanks guys! I thought so but i've been accused of being a cut first, measure later, kind of guy and didn't want to go down the road with this build.
the YS block just has the 4bbl. camshaft, that you will replace with an 068 or a different grind.
